When you say including the linear regulators, that means the capacitors and other components that go with the power supply circuit also, right?
I suppose I would have the box for the power supply near the wall outlet and then I'd run a cord with the correct DC voltage into the Theremin box. Is this what you mean? If so, that would complicate the power connectors, because I'd need one from the wall cord into the power box, one out of the power box, and then another into the Theremin.
Can I buy a "standard" power cord from Mouser or Digikey. Is this just a cord that has a three prong plug into the wall and then an output that would match the Qualtek adapters? In that case, I could just use 3 Qualtek adapters, 1 wall outlet to IEC320 standard cord, and another double ended IEC320 standard cord that goes from the power supply to the Theremin. Does this seem right?
Thanks,
Dan
Thanks,
Dan
