basic experiments
Posted: 11/22/2016 10:53:57 PM
Now some results of the volume control. Here please find a short mp3.
JPascal Theremin volume control test
 Volume Control JPascal Theremin
Posted: 11/27/2016 5:49:40 PM
"The practical results are good." - JPascal
Interesting. What about the repeatability? (the FETs have a noticeable spread of parameters).
Posted: 11/30/2016 6:40:45 PM
The jFETs I use have about 150 to 200 Ohm respective to a gain-source-voltage = 0. Below - 1,5 V they are high resistance, more than 1 MegOhm. The knob for adjustment the volume control would easy compensate parameter tolerance of the Fets.
Resistance JFet BF245a
Спасибо за интерес.
Posted: 4/2/2017 5:43:52 PM
Now I have posted a little 2 minutes video, shows an unusual replacement of antennas...
https://youtu.be/ZZYaoMSDtao
Posted: 5/14/2017 2:13:47 PM
Now, back from my short excursion to the antenna fruits, vegetables and berries, which allows a lot of basic experiments, the next subject waits for solution.  smile
To give the theremin a sound like a classical instrument the envelope of theremin output signal should be shaped by parameters Attack - Decay - Release - Sustain as used in synthesizers. The initial part performing a tone on a violine or a wind instrument is an example for this.
Volume pegel pushed by hand distance to the antenna and the dynamic movement of the hand allone do not produce an suitable adrs envelope in many cases. I look for simplest ways in combination with my voltage controlled resistors with FET-Cascade.
Tips are welcome.
