basic experiments
Posted: 10/25/2019 6:06:35 PM
A further thought to theremin as a voice
Normally, a theremin has -after heterodyning and demodulation- no formants. Playing a deeper or higher tone - the  time signal form is always similar, only the duration of the time periods changes. Due to a.f. filtering some phase distortions occur, but thats all of effect.
The more ripples are within one time period the more intensive and amplitude-different overtones higher order you get. This is the key to the timbre creations. If one would interpret the harmonics maxima here as formants, the theremin had sliding formants along the pitch.
Using the derived formant-frequency formula above: In analogy to the voice of humans, these behavior would be only reachable by changing the speed of sound in air.
The theremin comparison with human vocal voice is therefore reasonable, if we imagine the pitch high of the voice would be varied like helium speech.
Posted: 10/30/2019 6:44:47 AM
The screenshot below shows the effects of formants in a waterfall diagram. Here fixed pitch with manually varying multiple resonance maxima by a filter circuit.
Posted: 10/30/2019 11:57:54 AM
JPascal, I've noticed that a lot of vocal researchers compensate for the harmonic rolloff of the excitation ("tilt the spectra up").  This normalizes their calculations, and it makes it so the relative levels of the formants can be read directly from the spectral humps.  It also makes some of their papers difficult to get real data from!
Posted: 11/3/2019 2:26:59 PM
That is a new aspect for building a theremin: one unit only influences the timbre (tones with their harmonics in fixed ratios) and a second independent one is for formant sliding.
An interesting online tutorial about some basics of music I found in the german website http://www.lehrklaenge.de by Markus Gorski.  There are charts with time signals of instruments like this:
I am wondering if such curves can be created with theremin.
Posted: 11/8/2019 9:52:08 PM
Some experiments later. Yes, a heterodyning theremin can produce a sound similar to the above curves. And the theremin can transpose this sound in lower and higher pitches than a transverse flute for example.
