Posted: 9/8/2021 5:49:00 AM
andreyrogatkin
Hi, Buggins! Please check your private messages. I can't get in touch with you
Posted: 9/15/2021 7:11:37 PM
Buggins
Created teensytheremin organization and theremin project on github.
Will put all schematics and firmware there.
Created github pages site with description of project - for documentation, build instructions, etc.
Posted: 10/16/2021 3:55:23 AM
Buggins
Project pages updated
Published Teensy 4.1 Theremin Main Board KiCAD project and schematics in PDF
Published Teensy 4.1 Theremin Display and Controls Board KiCAD project and schematics in PDF
Previous LT1711 comparator based oscillator is unstable (starts oscillating at high frequency) when hand touches antenna.
New candidate for oscillator is described in this post
TODO: BOM and soldering instructions
Posted: 10/22/2021 1:57:50 PM
Flounderguts
Good article on mcu oscillators...
not sure if it will help, but I thought of it when I was reading this...
https://en.wikipedia.org/wiki/Numerically-controlled_oscillator?wprov=sfla1
Posted: 10/22/2021 6:03:43 PM
Buggins
It might be useful for FPGA theremin implementation - e.g. for generation of reference frequency in phase shift or pll based sensors.
Not for usual oscillator.
Posted: 10/22/2021 6:16:16 PM
Buggins
Unusual current sensing oscillator: details in this post
LTSpice model file is available on GitHub
SN74LVC2GU04 and other component models can be downloaded here
UPD: adding several output buffers in parallel provides bigger drive current. With 2 additional inverters in parallel with existing one gives 400Vpp on antenna.
LVC2GU04 model is a bit strange. Sometimes, provides empty signals - neither current nor voltage is visible in components connected with U04.
Does someone know where to find good lvc unbuffered inverter model?
Capacitor added to R7/R8 reference voltage sometimes helps.
Posted: 11/10/2021 11:41:19 AM
Buggins
New candidate for digital theremin sensor oscillator. Details in this post.
Posted: 11/30/2021 6:29:05 PM
Buggins
Based on discussions with Eric at Wallin Oscillator thread, I'm starting Teensy 4.1 MCU based Digital Theremin from scratch.
Two ideas:
1) provide descent digital PLL theremin sensors based on cheap small FPGAs.
Gowin GW1N-LV1QN48C6/I5 chip with 1K LUTs is selected as FPGA, in prototype - as $6 Sipeed Lichee Tang Nano FPGA boards.
Analog front end boards will be placed on separate PCBs, for experiments with different types of front ends.
Two FPGAs will be used - one per sensor.
To minimize CPU resources usage for sensor data transfer from FPGAs to Teensy MCU, we will use i2s data channel.
Pitch and Volume sensor values will be packed as left/right channel data for each sample.
FPGA boards will be controlled from MCU using slave SPI interface - as a set of registers.
As well, it may be possible to upload FPGA configuration directly from Teensy using slave SPI interface - if MODE0 pin of GW1N is tied to +3.3V
2) use Android tablet for UI and controls - instead of small LCD, encoders and pots.
Teensy can be connected to android tablet's USB OTG e.g. as serial port device.
Application on Android will work as GUI and control.
Teensy MCU will spend most of CPU time on voice synthesis.
Planning PCB and cabinet.
I think plywood laser cut technology for cabinet fits ok here.
Cabinet dimenions: 400mm width, 74mm depth, ???mm height.
Inductors frame: 32mm polypropylene water pipe, 60mm length, 0.1mm / 0.125mm copper wire winding 35-40mm length.
Antennas: water/gas pipes similar to Etherwave ones.
Mic stand mount on bottom of cabinet - e.g. AtlasIED AD-11B Surface Mount Female Mic Flange 5/8-27 Thread
Legs to allow put cabinet on table.
Minimal size of main PCB - 200x60mm
Front panel connectors:
    Line Out 6.35mm audio jack
    Line In 3.5mm audio jack
    Teensy MicroUSB connector
Rear panel:
    Power In DC barrel jack: 5V 2A
    S/PDIF Optical Out
    S/PDIF Optical In
    Teensy MicroSD card slot
    Expression Pedal 6.35mm audio jack
