In an ongoing quest to pervert Dewster's D-Lev design into something that he no longer recognizes, I am now working on the fourth iteration of a prototype (hence the PIII title...wait, what?) that further deviates from his vision. He is going to rue the day he ever let me in on this. Like the movie director that completely loses control of his or her visionary film to an uncooperative editor, I bring you D-Lev PIII: Return of Conventional Ergonomics. Directed designed by Alan Smithee.
Inside jokes aside, what started out as a quick breadboard build of another D-Lev theremin that would allow easy access for testing has blossomed into a new enclosure design. I wanted something that had all of the boards spread out and accessible so that several different types of inductors could be easily swapped and tested. At the same time this would give a good opportunity to try having the tuner built right in the front panel of the enclosure (my EW "Pro" style of enclosure for my first real D-Lev has the tuner on a separate stand). As it turns out this seems to work pretty well.
D-Lev Prototype II goes straight to DVD
What happened to D-Lev II (a.k.a.RPII)? Well after spending probably a couple hundred hours designing and printing parts to build a few, I've back-burnered it in favor of a simpler cabinet that is practical and potentially easier for someone else to build. I was very happy with the some of the quick assembly features in the RPII, but it still had those curvy parts that add complexity and scare off DIY builders.
The pitch arm is active and has a spring-loaded connector that allows it to plug into the housing and lock with a quarter-turn twist. The angles of the pitch and volume antenna are friction-adjustable to allow them to be set correctly for different angles of the body (see the tilt adjustment below). On this prototype the sides and back are walnut and leather, and the front is maple machined with a slight compound curve. The bezel on the back just below the rear attach point provides a window for all of the connectors, and in fact the front panel would provide the support for all internal electronics. The front panel could be separated from the housing by removing the two screws on either side of the bezel, and the front panel and all electronics could detach by removing a single narrow ribbon cable.
I like a lot about this design including the closer volume antenna when the body is tilted at an angle. But I'm actually getting a little tired of the vertical cabinet style of my "Pro" D-Lev (and the Claravox too, and it hasn't even shipped yet). I may eventually finish this one because it is so far along but probably not the five that I printed all of the parts for.
Enter the RPIII D-Lev:
This has a sloped panel to accommodate the LCD and tuner displays and to get away from having to crouch down to reach the front panel controls. And by reverting back to an Etherwave-type of horizontal cabinet it also dispenses with the pitch arm needed to gain antenna spacing when using a vertical cabinet. I think it goes back to my early lust for an Etherwave Pro, but tastes and lusts change.
Something like this (keeping in mind this is a breadboard):
Actually the horizontal form-factor enclosure kept popping up in my thoughts, but the thing that seemed to keep killing it was the amount of finger space for the two columns of four encoders that serve as soft key controls on the display. Several knob layouts were tested to stagger or slope the alignment of the encoders, but nothing felt right compared to two columns on either side of or below the display. The height requirement for this encoder array had prevented me from delving into a horizontal enclosure until I gave up completely on the pitch-arm concept and decided that I had to make it work.
Finger spacing for gripping the encoder knobs plus the diameter of the knobs themselves was taking too much vertical height, so I decided to cut both down. On the bench I usually just use the knurled shafts of the encoders themselves without knobs; it gives a good grip even at 6mm diameter plus the small diameter gives a good feel for the encoder detents. After trying some small diameter 3D-printed knobs I think the solution is going to be either narrow printed knobs or molded rubber sleeves.
To maximize the space available for the knobs without placing them on either the front or top panels (neither of which work for both seated and standing playing positions) the sloped panel was again chosen (it was on the very first P0 prototype), and this has the added benefit of deviating a little from the simple boring rectangular box appearance of the Etherwave.
Another problematic issue for easy construction (I'm thinking of the DIYer again) is what to choose for a front panel material. Encoders, switches, displays, and pots like panels around 3mm thick or less. While thin baltic birch plywood works if you cover it, thicker wood requires routed cavities on the back side around components and modules. 3D printed panels take time and have appearance issues, and metal requires machining and still needs a coating or an overlay.
So I'm back on board with using bent 1/8" cell-cast acrylic for the entire front-top-back panel attached to a wood base with finished hardwood ends. It's hard to improve on this for a balanced combination of professional appearance and ease of construction. Anyway, that's my current storyline until I change it. I think my first P0 prototype was on the right track, once I make the cabinet smaller and get rid of the pitch arm:
A little better acrylic bender
I think that flat or bent acrylic has so much potential for theremin panel or enclosure construction that it deserves to be described in some detail. The acrylic could also be used simply as a non-metallic but bendable base material, with the surface finish being textured vinyl, leather, wood veneer, wallpaper, or yes, as a last resort, even speaker grille fabric!
To bend 22" long acrylic panels a larger and higher wattage hot-wire unit would be needed. The panel in the photo above was bent over my knee after heating with a piece of nichrome wire stretched on a board, but going forward something more accurate and repeatable would help greatly. I looked at various commercial hot-wire units but they didn't really didn't have the bend-radius versatility that I was looking for. You can get a water-cooled 24" quartz strip heater for $100, but you can't control the exit aperture to narrow or widen the heat zone. Plus they use a quartz element that I expect is either unavailable as a spare or it exceeds the cost of the whole heater. And you have to haul out a bucket of water when you want to use it.
Instead I built a new adjustable 0-24VAC 40-amp power supply and a 24" aluminum and wood, air-cooled strip heater that uses a twisted pair of 20ga nichrome wires for the element. I should point out that these actually aren't benders. They are only the heaters, but once you soften the material along a line you can easily make bends over anything that has two planes at the correct angle. In fact most of the hinged benders that I have seen are pretty sloppy and in fact obscure some of the cues that you need to obtain the precision to make the acrylic parts that actually fit the wood parts.
The twisted nichrome wire is spring loaded to keep it stretched when expanded. At temperature the wire is about 10mm longer than at room temperature:
BTW, since this is air cooled it can only be used intermittently for safety reasons. There are air gaps between all wood and hot aluminum, and the wood does not get hot. Nevertheless, you don't leave something like this turned on when not in use (I have a darkroom timer to turn it off). The wood was needed to provide a non-marring surface for the acrylic, which must be bent with the protective paper removed.
The angles are polished on the sides facing the wire to lower the aluminum's emissivity, but the heat that the angles do absorb is at least partially dissipated by air convection around the rest of the material. The height of the wire and the spacing of the two angles is adjustable to allow some control over the beam of IR that is projected onto the acrylic. The top edges of the wood platens are in the shadow of this beam. Thus far this is providing very uniform bends of either very sharp or large gentle radii. After some trial and error it seems that the formula for success is to keep the wire quite far from the plastic and allow more time for the plastic to heat somewhat uniformly throughout the thickness. Four minutes at 400 watts seems to be a safe combination so far.
So what's the feeling on acrylic/wood for theremin enclosures? How about ergonomics in general?
And if there are any left-handed players watching, what specifically would you want to be reversed for a left-handed theremin? Antennas would be of course, and to keep the LCD in front of the player that would be swapped with the tuner. But how about the elements within the tuner itself. Would it be okay the way it is or should the circular scale and the volume LEDs be reversed as well?
