[i]Does it matter which guage wire I use for different components?[/i]
For this circuit no. For the T42-1 the 22AWG fits nicely in the side hole and the 28AWG fits nicely in the bottom hole.
[i]You told me the type of potentiometers you used for your theremin, and I think I'll go with them. However, the tolerance on those is 20%,
and the ones in the plans is 10% (the tolerance is not specified in the plans, but that's what it is on the Clarostat pots in the plans). Should the 20% work / did they work for you?[/i]
I did not have any problems with the pots on the pitch oscillator. I did not build the the volume oscillator but I would be surprised if the tolerance is a problem.
[i]I'm not quite sure what type of IC DIP socket I should get. The pitch of the LM13600 leads are 1.27 mm, but I'm not sure about any other of the specs. Do you know the serial number of the socket that you used for your LM13600? I think the 1-390261-4 may work ("with .300 center line ladder side"). Another with .600 center line is available, but I'm not sure which fits my IC- I don't even know if the pitch fits
it.[/i]
Do not buy that type of socket. Since you only need one socket look for a socket with machined contacts. The machined contacts mate with
the pin on four sides. I did not use the LM13600 and all of my boards are SMD.
[i]What about that power supply? :)[/i]
That power supply will *NOT* work. You need an earth-ground (third prong) connection. Also I believe the etherwave transformer has a centertap. You need to look closely at the EM Theremin schematic and the power supply
transformer datasheet. Also look at the Hotrodding the Etherwave article.
[i]When you built your theremin, what did you use for the antennas/ rods?[/i]
I used an antenna from an old radio. You could use the pipes as called out in the article.
[i]Where can the knobs for the pots be purchased?[/i]
All (http://www.alliedelec.com) * New (http://www.newarkinone.com) * Digi (http://www.Digikey.com) * Mouse (http://www.mouser.com)
(* jcl *)
it.[/i]
(* jcl *)
