[i]The plans call for a 12VAC power supply, so if I get the 12VAC transformer at RadioShack and follow the schematic shouldn't I have the correct values in my power supply part of the circuit, or do I need to do more than just follow the schematic?[/i]
The Hot Rodding the Etherwave schematic calls for 14VAC.
The only problem with the 12VAC transformer is the tolerance of the 12VAC. Since you do not require a lot of current you will probably be
OK. Test it before you solder it in your circuit so that you can return it if it doesn't work.
(* jcl *)
(* jcl *)
