Hello, I know most of you are aware of this by now, but for the newcomers, I just wanted to offer a bit of info about the problems presented by metal music stands near theremins.
I've learned from trial and error, that a metal music stand, or evin wooden, or plastic stands that have metal parts in the corners of the music holder can cause problems if they are too close to the pitch, and evin volume antennae.
The best advice I can offer here is to look for music stands which have all wood, or all plastic desk or music holders. It's ok if the mast is metal because that part will likely be in the zero beat zone. However, if the mast does cause problems, it should not be to difficult to replace the mast with a wooden dowel.
Avoid stands that have folding music holders because of the metal parts that hold the holder together.
I've seen some nice non-folding wooden, and plastic stands, and one particularly interesting folding plastic stand that uses a metal mast. The nice thing about this one, is the music holder is plastic, but it's molded so the holder folds up without any apparent metal fittings that I can see. I've just ordered it, and by the end of the week should have it to check out. I'll let you know if it works, or not.
If anyone has this model, feel free to let us know how it works, or not.
I got it from www.harpcenter.com
Just enter 8241S in the search box, and you'll see it.
I've seen wood and plastic stands in some pretty high press ranges, and a few that were cheaper, but this one seems to be the best feature vs price scale so far.
I'm sure some people have found ways of using metal stands near a theremin with little problem, but probably had to have it so far from the instrument that those of us who are visually challenged might not be able to use a metal one. An all plastic, or wood stand offers the ability to get the music close enough for a low vision thereminist like myself to work without problems.
But what about music bound in 3 ring binders? Well, I've seen some binders that use plastic rings and fittings rather than metal in office stores. You may not have any problems with metal rings in binders as these parts would be well within the zero beat zone. If I'm not mistaken, I've also seen folders with a bit of metal in the corners of the folder for looks, or perhaps for strength. I'd avoid those folders. Evin a paper clip can cause problems, so use adhesive tabs, a sticky, or postit note to mark your music with.
Any thaghts?
Any thaghts?
