"The theremin is designed to be played without touching the antennae, dewster! Thus it's not a design problem, but the user's fault if he doesn't touch a grounded part, i.e. the front panel, to discharge himself before touching the antennae, though. Such simple precautions are (IMHO) self-evident." - Thierry
Sorry Thierry - but I completely and utterly disagree with everything you say here! Good electronics should cater for all likely reasonable "abuse" the user can subject an appliance to - touching an antenna when the instrument is grounded through even a "permanent" audio connection lead (even if not powered) without prior discharging of static they have unknowingly accumulated IMO MUST be regarded as an extremely likely occurence - even for the most careful of users!
"Couldn't you put an insulating sleeve on both the pitch and the volume antenna?" - Gibarian
Yes - I think this is a good idea for many reasons - it will also probably somewhat reduce ESD risk.. But it cannot substantially reduce the risk - One can easily get 12kV (12000 volts) or more charge on an insulated human, and this will spark across standard sleeving.
But, to me, this whole issue is completely absurd! Its SO EASY (and cheap - certainly less than $5 for full protection) to fit the required protection if one does this at the design phase that, IMO, neglecting to do this, and risking failure of instruments one supplies to customers, is utterly inexcusable..
Probably grossly incompetent and Utterly and completely inexcusable! - Perhaps the only excuse being the vintage of the design, when attitudes to ESD were more lax - but these days there is absolutely no excuse! - And for something like a theremin which has a high probability of being subject to direct ESD discharge into a high-Z antenna and sensitive circuitry, not providing simple protection with a neon or discharge tube was bad - even in the '60s!
I know - critisising anything Bob Moog did is "dangerous" - He was a brilliant designer of low power analogue and synthesis circuits - but IMO wasnt any genius when it came to good safety / reliability practices, particularly with regard to power supply and ESD.. The real disgrace, IMO, is that modern designers at Moog who must have been exposed to more ESD awareness than Bob was, have done nothing to correct the risk.
Electrostatic discharge (ESD) costs the electronics industry millions of dollars each year in
damaged components, non-functional circuit boards and scrambled or missing information. ESD
can occur in the manufacturing, shipping, receiving, and field handling of integrated circuits or
[computer] Circuit boards with no visible signs of damage. A malfunction in these components or boards
can occur immediately or the apparatus may perform for weeks, months, or even years before an
unpredictable and premature breakdown causes a field failure.
" - Intel
And an antenna without ESD protection is effectively the same as having the board exposed - in fact, its worse - because this board is deliberately grounded, and a large area (the antennas) wired to it waiting to be touched!
