Replacement Etherwave Antenna wanted
Posted: 10/6/2011 9:38:36 AM
ChesneyDigitalStudio
Need a replacement for this broken antenna. The antenna seems to be broken right at the base, yet the threading of the Theremin itself is good.
url=http://a3.l3-images.myspacecdn.com/images02/115/746261a0af2149af830cfa7f80debb6a/l.jpg
Posted: 10/6/2011 12:41:01 PM
Jeff S
I'm sure Moog Music will sell you a replacement antenna.
Otherwise, in the short term, it is a simple 3/8" compression fitting. If you still have the nut, all you need is a 3/8" ferrule (compression ring).
[edit] I should have mentioned you can find these with the tubing fittings in the plumbing department of your favorite hardware store. You can get another nut there as well. [/edit]
If the antenna is actually broken (shorter), that may affect the tuning just a bit (higher).
[edit] If that is the case, you may be able to counteract the effect by picking up a few 3/8" washers while you're at the hardware store. Just slide a few of them over the pitch antenna (to add mass) until you're happy. [/edit]
Posted: 10/6/2011 12:59:09 PM
Awesome Jeff, that was the info I was looking for thanks!!!!!
