Has anyone ever tried to make a Goldberg style lightning bolt antenna?
Tips for bending antennas?
Posted: 3/22/2005 2:56:15 AM
If you use a strangely shaped antennae then the EMF generated will be strangely shaped too. Also, have you tried using a strip-heater or oven rather than just a section-heater. The problem with using heaters is that if onely one section of the material is heated then only that part will bend. . .
Posted: 4/7/2005 4:12:43 PM
I've managed to succesfully bend a loop aerial with a home-brew jig.
I used 6mm Dia Aluminium tubing with a 1mm wall.
I've converted some stills into a .WMV file, around 600K. If anyone would like it emailed, drop me a line and I'll send it.
It's made for use with the Silicon Chip/Jaycar Theremin Kit. More soon on this project!
Abdul
abdul.nathekar@blueyonder.co.uk
Abdul
