OK so I have a theremax kit with the theremax case kit.
I have some questions about the CASE. Putting the electronics together looks as if I can understand and manage to do that. I have put stuff together that I designed from scratch so that were about as complex. It is the case instructions I find illogical. I am hoping someone with wood experience can help me a bit. I am not a wood working type person. I generally use metal or plastic cases and just screw everything together.
1: You are to glue the case together before you apply finish?
Why can’t I apply finish to everything first and then glue it together? (Is it because the glue would not stick)
2: After the case to all together you then mount the front panel to the inside of the case.
This would seem to be somewhat hard to do.
If I applied finish to all the parts THEN did the electronics THEN mounted the front panel THEN screwed / glued everything together it seems it would be easier to do it this way. There has to be a reason for putting it together the other way. Any idea why?
Oh what do you thing about just using mineral oil for a finish? The only TUNG oil I could find is from MINWAX and it states it is toxic. ]:8|X
Thanks in advance.
Thanks in advance.
