OK this is where I should be - building an Etherwave
Posted: 1/28/2007 7:17:01 AM
lowfer
OK so the kit I got is an older one, the videos are on VHS lol. And the AC adaptor is missing.
So, what will work best, a center-tapped transformer, say, 15V each side, with the center tap as ground, or a 14-15V non-center-tapped transformer with the ground to the transformer case? I can probably find a suitable transformer on monday, and build it into a BUD box.
If all I need is 15VAC non center tapped, I can use my little Variac for now.
Posted: 1/28/2007 10:17:58 PM
lowfer
OK problem solved, I just went back to Santa Cruz and sure enough, the wall wart was in the bin at the shop.
And I got a mic stand and amp, kinda need those.......
