PCB-layout for EM Theremin?
The article in Feb 1996 Electronic Musician "Build the EM Theremin" by Bob Moog is another useful reference - whilst the schematic is not identical to the EW, it is close enough that the basic layout could be modified slightly to build a EW copy.
My expierience is that layput is not too critical - just keep oscillator sections as far from each other as is reasonable, and DECOUPLE POWER SUPPLY CONNECTIONS WELL! - it is supply bourne HF which caused me the biggest problems (unwanted oscillator synchronisation) in the early days.
Much more fun to design your own board than to copy someone elses! .. Design it, do a 'breadboard' version first (based on your PCB layout) if getting a PCB made is a major effort, then go to PCB.
By the time one researches and acquires the resources to build a knock-off of this great Moog Theremin, one could purchase a Moog Etherwave for less.
JUST BUY ONE! Keep the company in business,and get a warranty to boot!
Duh!
teslatheremin
"By the time one researches and acquires the resources to build a knock-off of this great Moog Theremin, one could purchase a Moog Etherwave for less."
I agree wholeheartedly.. The cost (time) of laying out a PCB, the cost of getting PCB made, the chance of getting something wrong and needing to re-do the PCB, the cost of components / assembly.. If one wants an Etherwave, buy an Etherwave - it will work out cheaper and more reliable than trying to do a "knock-off"..
However, if one wants to learn about the electronics and design your own instrument based on the Moog designs, that is a different matter.. sure, you will probably end up spending asa much or more money, and spending a LOT more time - but you will have an intimate 'relationship' with your Theremin which would far surpass what you will get from building a kit or just copying the Etherwave.
All schematics are available.. these 2 links are for the 1996 EW Theremin construction project from Electronic Musician magazine, and the Etherwave manual
http://www.moogmusic.com/manuals/HotRodEtherwav.pdf
http://www.cs.nmsu.edu/~rth/EMTheremin.pdf
article. I did a PCB layout for the pitch oscillator using the schematic in the article. Apx four hours of work.
My main curiosity is the difference in the analog
and antenna sections between the EM Etherwave and
the high-end $1K - $2K Moog Theremins.
Is there a larger pitch range? Is the pitch range
more linear?
Also, I noticed in the PCB picture of the Etherwave plus the orientation of the antenna coils is different. The article stated the
coils should be parallel and the windings should
be in the same direction.
(* jcl *)
Thats mainly due to that the autoroute didn't manage to get all the connections on a single-sided PCB and also that my knowledge about routing is quite bad..
