I have now added an audio output amplifier and some minor refinements, and done a simple breadboard layout.. and pasted this at http://www.therasynth.com/html/a4093cct.html
This was in response to an email.. I include this here as it may be of interest to others:
>> Have you built this? Do you have a picture of a completed circuit?
I have built numerous versions of this circuit into other products, but do not have a "stand alone" version I can photo or demo.
>> You say the output can be connected to a High-Z amplifier, is a guitar amp high impedance? So, this output can be a 1/4" jack, which
can be connected to any amp?
The ideal would be to have an op-amp configured as a follower, before driving an instrument amp.. However, with component changes, it should just be capable of driving an amplifier directly
>> Where is the voltage source for this circuit? Is that 9 volts into the CMOS chip?
Yes, the circuit shown is a full simulation. 9V would be applied to the 4093 (pin 14 to +9V, pin 7 to 0V) - You should also be sure the supply is stable (no problem with battery) and have a 100n decoupling capacitor soldered between pin 14 and pin 7, as close to the IC as possible, with as little wire between the IC and the capacitor as possible.
>>I do not understand the distinction between the ANTENNA and C2, where you say that C2 is the capacitance of the circuit. Please clarify.
>>Suggestion for an antenna design?
C2 is not actually fitted on the board (or anywhere).. It is put on the circuit purely to allow the simulator to 'pretend' that an antenna is connected.
The capacitance of the circuit (capacitance between IC pins, tracks on the board, wiring to the antenna) and the capacitance of the antenna to 'ground' (the battery 0V, or - terminal) is usually in the order of 20pF, going up to about 25pF when a conductive object is extremely close.
NOTE: IT IS CAPACITANCE BETWEEN BATTERY - AND THE ANTENNA WHICH IS IMPORTANT.. IF BATTERY - IS CONNECTED (Via, for example, the earth on an instrument lead) THIS WILL IMPROVE COUPLING. I HAVE SHOWN A GROUND "ANTENNA" TO EMPHASISE THIS.
See my posting on the " I want to know everything about the antenna" thread for more information on antennas.
>> What are the blue arrows, pointing to R#(#)?
These are the test points on which measurements are taken (scope connected) - If you look at the waveforms (say the bottom right one, labeled "VARIABLE (PITCH) OSCILLATOR" you will see R2(2) above this waveform.. this shows that the waveform is what you would see if probing the point marhed with the blue arrow as R2(2).. Effectively, each component has reference 'terminals' - a resistor has terminal 1 and terminal 2.. with resistors, the order these terminals occur in a circuit does not matter - with diodes, for example, it does. The reference R2(2) is simply shorthand for Resistor 2 Terminal 2.
>> What is up with the variable resistor, RV1? Is the green arrow simply to indicate that the potentiometer is set to its half-way position?
It is a variable resistor constructed from a potentiometer, the pointer is the wiper, and, yes, as shown it is set to mid position.
A potentiometer has 3 terminals.. These are the resistor track ends, and the wiper.. connect the wiper to one of the track ends and you get a variable resistor. IT IS A GOOD IDEA TO DO THIS WHENEVER YOU NEED A VARIABLE RESISTOR - If you simply connect between wiper and one end of the track, the wiper going open-circuit will present a high impedence.. Tying the wiper to one end means that worst-case, the failure resistance seen will be the full potentiometer resistance, not a disconection.
As (I think)I mentioned, RV1 should be a trimmer, and another REAL (manually adjustable) variable resistor should be placed in series with it as a user control.
The most (only) tricky bit of this circuit is getting the values f
