Hi all-
Can anyone help with suggestions for a PAiA Theremax I’ve (sort of) built?
Back in 1998, a friend and I got kits, and started building them. We’d solder four components, then trade circuit boards and inspect each other’s work. Just as we neared completion, I met my wife, and suddenly had a much harder time finding time for our project. My friend hooked his up and it worked, while mine was mothballed. As time went on I got married, moved twice, and had kids. Then, last Saturday, as my 6 year old son watched, I checked my email, and a kitty+theremin video popped up. He loved it, and I told him about the incomplete theremin downstairs from a decade ago!
So we got it out of storage downstairs, and followed the instructions. The power LED turned on when the theremin was turned on – so far so good.
I turned L1 – L4 all the way out as instructed, and set the knobs as instructed (vol trim & pitch trim in middle, CV, timbre & vel all CCW, Vol at 45%), and shorted lug # of R83 to the band end of D1. Then, I turned L3 slowly in while listening for the null point. I was using just a little set of computer speakers for an amp. It was pretty low volume (turned up all the way), but it worked.
I found the rising and lowering tone, and noticed that it was vol trim, not pitch trim, that then changed it (unlike what the instructions said). At that point I could get a (weak?) response from having a hand near either antennae!
But then I noticed that I had null pointed L3, while the instructions said L2. I turned L3 back to it’s all the way out position, and tried to null L2. No response. I tried taking off the short – no response. I tried putting everything back the way it was, and couldn’t replicate what I had done with getting it to sort of work previously.
I thought I might have had the short on the wrong end of R83, so I turned off the power and switched it (to lug #1). I turned on the power, and the power LED came on, then quickly faded. I immediately unplugged it, worried that I had damaged it, and then restored the short on R83 to lug #3. Plugging it back in, the LED came on fine, but as before, I still couldn’t replicate the response from the antennae, no matter what I did.
So can anyone help? Is it clear whether or not I damaged it by having the short incorrect – or was that a harmless mistake? Or is this just because my amp is so small? Should I try wiring it into the line/ext of a boom box? Is it clear what is wrong, or what I can try next? I've found a nice case and the kids are all excited.
Thanks for any help anyone can provide.
Equinox
