Thanks
Moog 1954 coil question
Thanks
To me, there would be little point in going to the trouble of procuring coils for this theremin, and then ignoring the explicit instructions that these are "the heart" of the machine - if you do that, you might as well have wound coils based on the instructions, but using easily obtained materials.
I think that the pitch coil is the more important one - so having an original, unmodified one of these is the most important.. The volume coil could be constructed in some other form if you messed up the modification.. Leaving both coils identical is likely to cause interaction between pitch and volume oscillators, which really screws theremins!
Matt
Link to this is the first in the TW schematics page..
http://www.thereminworld.com/moog1954.asp
One could change the value of the capacitor across the coil, therebye changing the frequency.. BUT.. I think the change in capacitance would give a different sensitivity than the original.. If a simple change like this did not have adverse effects, I am SURE Bob would not have gone to the trouble of having different windings on each coil.
What I would probably do is this.. Measure the inductance + resistance of the original coil, calculate (roughly) what the specified changes would do to the inductance of that winding, then proceed - I could then check that the modified coil was close to the expected, and also have the essential data on hand, in case I needed to re-wind a coil because I had bodged it!
