Gakken Mini
Posted: 9/12/2008 11:23:49 AM
hypergolic
Is it normal to only have a range of about 6" from the antenna?
Is this why one of the mods is to provide a large diameter antenna for better control and playability? Just curious.
Thanks
PAN
Posted: 9/12/2008 9:28:19 PM
Thomas Grillo
I have two of those, and have yet to mod them with the foil. They both seem to stay around 6 inches or less. However, if you lean in to them with your body, the field will expand out a good bit.
You can also force a wider field by simply placing your other hand near the instrument.
If you do the mod with the foil connected to the batteries, you should get a better field, but you have to touch the foil strip, or hold the Gakken to do that.
