Showing Posts 1 - 8 of 8
Posted: 1/19/2009 12:41:08 AM
I got a Jaycar theremin kit for Xmas, and built it with no problems. I had just plugged in the power pack and was playing with no problems. I took off my jacket and then while playing I touched the pitch antenna, felt a static discharge, and it died! I'm sooo disappointed... how do I figure out what component got fried?
Right now if I turn up the volume all the way, I hear a faint, high sound, and if I move my hand around or touch the volume plate, the pitch changes.
I've read that it's likely this fried a transistor, but which one and how do I test? There transistors are the cylindrical "D"-shaped pieces with the 3 legs right? Marked 2N5484 and BC548? 4 of them?
Can anyone lend a hand? is there a way to ground it to prevent this from happeneing again? Thank you.
-John
-John
Posted: 1/19/2009 7:18:53 AM
Posted: 1/19/2009 12:16:04 PM
The most likely case are the JFETs. They are the most static-sensitive parts in that theremin.
Don
Don
Posted: 1/19/2009 8:09:27 PM
Posted: 1/20/2009 1:08:51 AM
OK, I'll try and replace the 2N5484's - Radio Shack's site doesn't seem to have them, any other place you guys can recommend to get them from? I googled and came up with this place (http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMv34NK1v5E8iQzIYI4uPWKYR1QNNblZYGY%3d). The numbers look right... I'll probably get a bunch of other replacements too (BC548), just to make the order worth it.
Thanks for the help guys!
Posted: 1/20/2009 3:44:28 PM
Yes, Mouser is a good supplier. Digikey is also a good place to get parts from.
Don
Don
Posted: 1/20/2009 5:59:44 PM
Posted: 1/22/2009 4:52:40 PM
.. And connect a small neon bulb between the antenna and ground for both antennas.. These are the NE-2 type with no resistor fitted..
This will prevent most future ESD (Electrostatic Discharge) problems, and cost under £1..
Provided the neon is wired close to the antenna connection, and the grounding lead is as short and fat as possible (low inductance and resistance) and connected to a good grounding point (the power supply input ground for example) tuning should not be significantly changed by this modification, as these neons have low capacitance.
Feeds:
