Etherwave specs...
Posted: 7/19/2009 2:37:37 AM
Ardor
I'm building a case and I have a question I hope and Etherwave owner will be kind enough to answer.
What is the distance between the two ends of the volume antenna? (The ends that connects to the case.)
And what is the length and depth of the case?
I want to make a case that can hold my Theremax but will also hold an Etherwave.
Thanks!
Harold
hauntingcreations.com
Posted: 7/19/2009 3:09:18 AM
The distance (center-center) of the volume loop connectors is 8.5cm (3.35")
The Etherwave housing has a width of 45.5cm (17.91"), a depth of 14cm (5.51") and a height of 6.5cm (2.56") without the table stands which add 2cm (0.79") to the height.
Posted: 7/19/2009 1:21:33 PM
Ardor
Awesome! Thank you for such precise measurements!
Not that I doubt you but I'm surprised that the distance between the ends of the volume look is only 3.35". Looking at the image of the kit it looks so wide.
http://www.instrumentpro.com/P-MOOTHERKIT.html
Its probably just the image or maybe the fact that its not in the connectors?
Shrug.
Anyway Thanks!
Posted: 7/19/2009 1:34:37 PM
This might be rather an Adobe Photoshop issue...
Since I'm an old man with midlife crisis issues, I checked the distance once more: 8.5cm is correct!
Posted: 7/20/2009 11:48:53 PM
Ardor
Cool! Thanks!
