[i]" Both oscillators oscillate with a clean sine wave. The variable oscillator has a higher output than the fixed one, but i reckon thats due to the power supply for the fixed. They both " mix / beat " and before the AM detector, I get the typical envelope waveform, and this drifts as your hand approaches the variable oscillator, however, after detection, theres no audio ?/ I 'm using the BAT diodes too, Help please anyone ."[/i]
I know you are saying you see the modulation signals - What follows is a general diagnostic routine which I have edited to include your specific component references..
Ok - First - You are getting waveforms from both oscillators.. BUT.. Are these waveforms at different frequencies? This is NOT easy to determine, as they could be extremely close or even 'locked'.. But (with a circuit like this which has unbuffered oscillators) observing / measuring the independent waveforms is difficult (this is one reason I now suggest that beginners start with the SC/Jaycar/EPE kits - They have well buffered signals you can put a 'scope or frequency counter on).
If you are not sure - You need to disconnect the common side (the side connected to TR3's base) of C11 and C12, and connect a dual channel 'scope to each of these 'floating' leads first.. Be sure that the oscillators are independent.
At the base of TR3 there should be extremely little signal - and a DC level of about 0.6V.. TR3 is quite strangely configured.. The voltage on its collector should be the signals from the oscillators mixed in a non-linear manner, to produce a waveform on the collector which is a high frequency (sum of the two oscillator frequencies) modulated by the audio frequency (difference of the two oscillator signals).
If you get this modulated waveform on TR1 collector (you should be able to view this with any reasonable 'scope - even if you cannot see the waveshape inside the modulation envelope) determine what the frequency of this modulation signal is.. it may be too high.. in which case the filters (c15,C16,R15 etc) may be rejecting it.
There is no reason I can see for any problem with the rectification circuit (D1,D2) .. If you are getting an audio modulation waveform whose AC amplitude is >1V on TR3 collector, You should get audio across R17, across VR1, and then on the wiper of VR1.... If you get audio here (and often the potentiometer / wiring to it, turns out to be the problem) then it is the output amplifier stage giving the problem.
If you have a high impedence piezo speaker or earpiece, this is a superb test kit for stuff like this.. probe about and trace the audio (if you dont have one, get one.. Piezo with series 1k resistor.. The most essential piece of kit after a multimeter!
