Perhaps this belongs in the misc. category, as this isn't a specifically theremin-related question, but rather about the vaguely related tannerin (electro-theremin, slide theremin, whatever), but here I go anyway:
I've been trying to make a tannerin using a wein bridge kit as the guts (rainbow kits). The problem I'm having is that the output level of these is in that annoying range of being too low to drive a speaker (not really what I wanted to do anyhow) by itself at a useful volume and far too high to use with an amp (uncomfortably loud with the volume knob at 0).
I've tried 100k pots to 1meg pots, linear and audio taper. Bridging the sleeve and tip of the output jack with a 10k resistor (yes, i tried higher resistors than that) helps, but does not get it to the point of completely blocking the signal. The idea was to have a volume control similar to that of the key on an ondes martenot. I could just use a momentary push button switch, but this would remove the possibility of having a "nuanceful" control over the volume...or any at all.
I have not tried putting a pot in one of the battery leads, but I'd think this would change the pitch and volume at the same time, which is not what I'm trying to do.
Clearly I'm no electronics expert, otherwise I wouldn't be resorting to the lazy method of using kits as the base for a project, and wouldn't be bothering you fine people with my questions.
