[i]my advice to anyone who discovers something 'strange' is to present what they have discovered WITHOUT trying to explain the mechanism - unless they are sure their hypothesis is rational and does not contradict the fundamental laws.. It MAY be that some physical fundamental will need to be re-evaluated.. But this is extremely unlikely - and if one presents a hypothesis which goes against these laws, no-one will bother examining the phenomena.[/i]
I agree with you Fred, that what I observed probably fell on deaf ears because my explanation of the phenomenon is most likely inaccurate. After seven years I have received very little theoretical feedback though all of my theremin designs have been linear.
Using a tight coil antenna gives a perfectly linear pitch field “relative” to the note intervals or spacing found on a piano keyboard, from the outside right up next to the antenna. This is what makes the coil antenna approach so interesting.
Today operating my pitch oscillator at 900 kHz instead of 850 kHz and using tubes/valves instead of transistors allows me to bypass using any sort of inline LC antenna tuning. The tuning is by the slight stretching of the spring antenna coil. This does not seem to be critical when using the spring of choice found at every hardware store here in the states. The tuning of the antenna is very stable indoors or out once it is initially set.
Understanding the phenomenon is not as important as it is to experience something so unusual over a standard theremin pitch field. The [b]Theremax[/b] operates around 820 kHz and might be a good theremin to try the Lev Antenna on. I would move the operating frequency higher in case freq is an important aspect relative to the dimensions of the antenna spring coil design.
One day most theremins will be linear, not almost linear, once someone explores this and makes a validating statement about the Lev Antenna (http://www.oldtemecula.com/theremin/index.htm).
Perfect linearity will not make anyone a perfect Thereminist but it does give you a significant advantage.
