volume antennae squeal - big problem?
Posted: 1/16/2007 1:50:47 PM
morerock
I was just searching the forums for mentions of squealing volume antennae, and found a member stating that it indicates a "big problem." Well, my newly built, otherwise beautifully functioning etherwave standard kit theremin squeals indeed when I touch the volume antennae. Why? How do I fix it? How big a big problem is this?
Many thanks...
Posted: 1/26/2007 3:03:52 PM
Thomas Grillo
Hi, you may have allready found it, but check out my fix for unintended sounds when touching the volume antenna over in the theremin construction forum. It's a simpl, cheap, and quck fix with an added cool effect. It involves sleeving the antenna.
