Okay, I bought a Moog Etherwave kit and I put it together, and now I can't get it to work.
All that comes out of the speakers is this really high pitched, quiet whine that I can silence with the volume antenna, but can't change the pitch of without using the knob, and even then it's negligable.
I know I didn't solder anything to the wrong port/whatever, because I've checked about 10 times. I also know that the paint I used was non-conductive. The main board is also probably not the problem, as I was very careful with it.
Did I just do a really bad soldering job? If so, can it be repaired? Does slight stripping on the outside of the compressor nut on the antennae do anything like this?
I hope this description is enough to help you help me.
