I just wondered if any of you have noticed a considerable decreased range on the pitch antenna depending on where you play the theremin...
I took min to work and plugged it in. Even tuned to the largest range the antennas lowest note was only about 30 cm from the antenna. I tried it in three differents rooms, with and without shoes on. It didn't change when it was warmed up.
When I start it up at home the range is much better, usually up to about a meter.. But it shifts depending on where in the room it is setup.
Is this normal? What can I do to expand the range when I play somewhere else?
