Hi, I play a Moog Etherwave Standard and have graduated from a Moog Keybaord Amp to a new KC60 keybaors amp. My normal playing volume was reaching a level that was causing the signal to clip with the Moog Amp. That drove me to larger amp. THe Kc60, brand new, is 10" compared to the MOog's 8" speaker size. It sounds distinctly richer, and I can definitely play it louder. But I still reach a similar clipping point... i.e. the sound gets raspy and distorts when you push the volume too far.
My questions are- do I need to keep trying bigger more expensive amps? My cables (cords) are not top quality - might the noise eminate from there? Some kind of resistance thing/contacts? I am not a tech head, but is there something inside the theremin I should consider tweaking or changing? I've ruled most everthing else out.
Thanks.
Thanks.
