[i]>>"FredM! in the circuits that you passed me, in the second one, the sensor will give a signal proportional to the capacitance value isn´t it?"[/i]
By the "second one" I assume you are referring to Smirnov's "Analog Sensor #2".. This is in 2 parts - The 'sensor' which will output a frequency which changes as a function of sensed capacitance (but the frequency change will be quite a tiny percentage of the total frequency - for example, frequency may vary from 485kHz to 490kHz) - And the 'Reciever' which has a reference oscillator and mixes this with the 'sensor' frequency to produce a 'difference frequency' - If this reference oscillator is tuned to 490kHz, then the sensor frequency above (485kHz to 490kHz) will produce an audio difference frequency from the reciever circuit, which will go from 5kHz to 0Hz.
[i]>>"I don´t know which is the voltage that I need to use and also how to calculate the value of the lineralization coils. some of the values of the capacitors aren´t specified. they are in pF?
I do really need your help.
thank for everything"[/i]
Voltage is not critical - anything from 5V to 12V should work - 9V from a battery is probably your best starting point.
Analog Theremin Sensor #2: This (as shown in the block diagram) gives an audio output when the signal from the sensor circuit is combined with the reference oscillator in the Receiver circuit.. This is a conventional Theremin – It DOES NOT output a control voltage to drive a VCO, it produces audio by heterodyning two HF signals (mixer consists of C7,C8,R12,D1 in the Receiver circuit.
If this is what you wanted, there are simpler circuits – This one is designed to allow the ‘sensor’ part to be located a distance away from the receiver.. But, having said that – There is no reason really not to use this circuit – it is robust and has no FETs to blow up..
Capacitor values are a bit obscure –
Sensor Circuit: C1=100n, C2=1.2n, C3=10n,C4=1.2n,C6=15n (n=nF. 1nf=1000pF)
C5=100u (u=uF, 1000nf=1uF)
Receiver Circuit: C1=680p,C7=22p,C8=22p
C2=10n,C3=100n,C4=100n,C5=1.2n,C6=10n,C9=3.9n,C11=1n
C10=47uF Non-polarised Electrolytic.
[i]>>"I need to use and also how to calculate the value of the lineralization coils."[/i]
Smirnov gives all the required information - Note, the coils determine oscillation frequency.
From Smirnov's (http://asmir.theremin.ru/tsensors_sch.htm) page:
[b]"It is important to match frequencies of sensor oscilator and receiver oscilator. They should have similar initial values. The relation of the frequency of receiver oscilator and it's inductance L1 will be as following: 6.8 mH (milli Henri) will give you approximetely 130 khz, 1.8 mH - 230 khz, 0,5 mH - 370 khz, 0.44 mH - 500 khz, 0.27 mH - 800 khz, 0.082 mH - 1 mhz."[/b]
You originally stated:
[i]"After the antenna, I want to put a F-V converter and then a function generator."[/i]
If you still plan to do that, you would take the Reciever output to the F-V....
But why go to all that extra complexity, when "analog Theremin Sensor#3" is far simpler and gives a voltage out directly ?
