Thierry E-Pro Mod - Part 3
Posted: 8/1/2009 12:44:34 PM
Etherspiel
[i]"If Etherspiel's volume field has contracted since he installed the module, it could be that the tiny inside screw whose access hole can be found just next to the ports where the loop plugs into the cabinet, needs to be adjusted. This screw is for gross adjustment of the volume field and the slightest change, even one degree, in its setting can make a HUGE difference.
It has been my experience (and I've had PLENTY, believe me!) that whenever you make any sort of modification to a theremin the entire instrument can be affected in a variety of unexpected, and sometimes inexplicable, ways. There's a kind of "domino effect" that happens. This can necessitate all sorts of adjustments to parts of the instrument that have nothing to do with the area you modified."[/i]
Peter, you hit the nail on the head. I went back to it last night and worked with the "gross adjustment" screw and was able to retune the volume control field to a larger control area. This had the a very positive effect on the performance of the module. I will need to adjust the instrument a bit more to fine tune where I would like it to be, but it seems to feel much smoother now with more expressive possibility.
Thierry - for technical information, my E-Pro is an early model, serial #71. When I returned the theremin to the original resistor, the range returned. When I again reinstalled the module, the range compressed. Retuning the volume circuit using the small screw on the side seems to correct the problem. You might wish to amend your installation instructions to include a statement that retuning might be required for optimal field.
Posted: 8/2/2009 12:05:32 AM
Etherspiel, thank you for this suggestion. I will add a chapter to the installation manual. It seems that the more you want to extend the range with my module, the more eventual previous tuning deviations are noticeable. I had the luck that the instruments where I installed my module myself up to now had no tuning problems and so needed no further adjustment.
Posted: 8/3/2009 4:21:29 PM
The tech doc and installation manual for the EPVM1345 module is now completed and a troubleshooting section has been added:
Click here (http://files.getdropbox.com/u/1548721/Theremin/EPVM1345_en.pdf)
Thank you for all comments and contributions!
Posted: 8/6/2009 12:53:35 PM
Etherspiel
Shoot!
I was playing the E-Pro this morning and noticed that when the volume hand is at loudest position, I hear faint radio interference. It is directly related to the hand position over the volume antenna. I never had this before installing the module.
Thierry?
Posted: 8/6/2009 3:09:06 PM
Life would be sooo boooring if there weren't such little hickups. I'm actually on the road and writing this from my cell phone. I'll think about this while driving home. Could you please answer the following questions:
Is the ghost tone's frequency constant or does it vary with pitch or volume? At which jumper settings does it appear? Are there settings where the effect becomes stronger or weaker?
Thank you in advance!
Posted: 8/6/2009 4:25:15 PM
Etherspiel
Thierry -
I currently have it set to "setting #3", and have not opened up the instrument to further check.
The interference seems to occur only when the volume hand is at the loudest position. The sound seems to be directly related to the volume portion of the instrument.
Posted: 8/6/2009 4:49:50 PM
I've a theory... Could you please check if the register switch changes something?
Sorry for the inconvenience, but I'm torturing my brain in order to solve this problem. Up to now you are the only one to have reported this issue, so you are eyes and ears at a very long distance.
If you find all this too annoying, my refund offer naturally still exists.
Posted: 8/6/2009 5:50:49 PM
Etherspiel
[i]"Up to now you are the only one to have reported this issue..."[/i]
Yes, I am starting to think my E-Pro hates your board. ;)
I will do the checks this evening hopefully.
As for others not yet reporting it, it may be that they haven't noticed it yet - I had not noticed it until this morning. The sound is faint, and only noticable when the volume hand is at "full volume" position. I noticed it when I was adjusting the timbre to a more muted sound, and then it was obvious. When I switched back to the brighter sounds, it was not as noticable as it is covered up by the harmonics - but it is still there.
The interference sound is very high-pitched, and although weak, it is enough where it would make the instrument unsuitable for recording, at least when using the full volume range. You might want to ask others to listen for this...
Posted: 8/6/2009 6:01:34 PM
I have now an EPro owner (naturally with my module) at 20 miles from here. I think I'll travel to him on Sunday in case he will be at home and try to hear it myself.
Some months ago when I did tests with a prototype board on an EPro in Munich, Germany, I really stressed the instrument in order to measure and calculate the overall dynamic range and verify the maximum output voltage. I'm sure that this EPro didn't have this problem because during these tests I have been looking and hearing especially for unmusical side effects. And please believe me, if I'd been aware of a potential problem I would never have started the module's commercialization!
I'm really sorry that this comes out as a problem for you - that was not intended!
Posted: 8/6/2009 6:13:22 PM
Etherspiel
It is no problem, Thierry - I am happy to help troubleshoot. I like the volume response and hope it can work correctly.
