"All I can tell you is that it is essential that the instrument be very exactly and precisely tuned before playing (I use an electronic tuner) otherwise things get "wonky"." - Peter
Thank you! The precision tuning (of, I assume, the strings, not the electronics) combined with the materials used, is a big clue as to its possible operation.
" It's like my car - I can drive the thing but I haven't the slightest idea how it works either!" - Yeah, im nearly in the same boat there ;-) - but with musical electronics I can (generally) understand workings better than I can actually "drive" the instrument.
If your harp does actually pick up both the "trigger" amplitude and frequency of each individual string, and resolves these independently into electronic signals, then the technology is beyond anything I have yet encountered - its not impossible that this is the case - I havent focussed a lot on stringed instruments because I find even a simple guitar impossible to play.. But I do not see any complexity at the bridge - which is where I would expect any transducers to be fitted - and with so many strings, I just cannot see each being picked up and seperately processed.. I can see the bridge acting as a composite pickup..
But whatever - I certainly couldnt "drive" the harp, and its quite likely that I dont have a clue about how it works! ;-)
Kind of makes me wonder whether theres some ET's working at MIT, and whether Star-Trek is a fantasy at all ;-) Perhaps its a genuine Vulcan harp, not the pathetic terran interpretation described in the star fleet manual.
http://cygnus-x1.net/links/lcars/vulcan-harp-construction-plans.php
ps.. Just realised another way it MIGHT work.. You say (or imply) that even minor tuning errors cause things to go "wonky".. This might be a big clue...
Perhaps the audio composite is filtered with an array of bandpass filters - sort of like a graphic frequency display - each filter tightly tuned to one specific string frequency.. From this, one could generate a voltage (or digital value) proportional to each strings vibrational amplitude, and would not need to derive the frequency as this would be known..
If the strings were off tune, this could cause havoc as the filters are fixed frequency, and all the data would be wrong..
Yeah - that all fits... One still has a composite acoustically generated signal to use (after bending if required) but one also has a set of values relating to each strings 'activation' which one could use to drive even quite a simple synthesis engine.
Funny thing here is that one could almost drive the simple top-octave generator as shown in the star fleet "Vulcan Harp construction plans" from the above - Ok, those parts are rarer than rocking horse poo these days - but a single FPGA and a few analogue bits and one could have a reasonable board for a basic Vulcan Harp...
The more I think about the idea, the more interesting it becomes .. Its an idea which cannot work on a guitar or any other stringed instrument where the pitch of a string changes - but for a harp, its extremely elegant and simple.. So simple its beautiful! .. With any harp or instrument having the correct FIXED FREQUENCY tunings,one could implement this kind of detection - probably even by just using a microphone. If the instrument is acoustic and has a functional resonator, bending would not work - but all (or many of) the chording structures could work, and synthesis engines could be driven from the 'decoded' outputs... In fact, even MIDI could be output... And latency could be quite low - probably in the order of 1/2 cycle as no frequency tracking is required...
*I also wonder if there is any acoustic signal getting to the output - perhaps the synthesis engine just uses the string amplitudes to drive a high quality wavetable or similar engine that sounds like a string - this would remove the need for any pitch shifting of the composite acoustic signal.
It might be quite simple to test the above hypothesis.. if repeatedly plucking a single in-tune string, one hears this being played through the audio output, and one slowly de-tunes this string.. If one is listening to the acoustic output, one should hear the pitch change.. If, however, one is hearing a synthesised output, the pitch should stay constant but the amplitude will probably change.. At some level of detuning, if the hypothesis is correct, the pitch (if one is hearing only a synthesised string) should jump to the nearest other string frequency - or one may hear two strings being played, probably at low level, and as the tuning gets closer to that of the other string, the amplitude should increase and the other strings frequency should play, even though the wrong string is being plucked...
If, when detuning a string, you dont hear this detuning coming from the speakers, then you can be damn sure that everything one hears from this harp is electronically synthesised... If you do hear the detuning, then one is hearing acoustic signal from the strings - and electronic synthesis signals from other voices. If all sounds one hears are synthesis, then my first hypothesis is entirely eliminated, and this latest hypothesis is possibly correct.
I know - it probably doesnt make any difference - but if you could observe whether you can hear the tuning through the speakers next time you need to tune the instrument, I would be real interested to know! ;-)
"It is a highly sophisticated synthesizer that uses the strings of the instrument as triggers"
Yes - I think this is the truth - my mis-thinking was probably with regard to how the triggers from each string were derived, and seeing the strings were tuned, the assumption that pitch tracking was required.. Closely listening to the plucked string sounds I am now feeling these are probably synthesised and not acoustic - Its difficult to tell because you play so well - but the sounds might be just a little too perfect, even for you! ;-) - and the bending is perhaps a little too clean and quick to be done by DSP.
It would be exciting to discover that I was wrong with regard to how individual strings were resolved, as this would possibly mean that id thought of the idea first, LOL ;-) But im reasonably sure now that the Vulcans invented it, and am quite satisfied if I have merely worked out what they did ! ;-)
