Two of the TW staff members showed curiosity as to what was on my myth list. I hope the staff doesn’t think I express heresy.
omhoge said: (excellent)
So what are the 13 forbidden truths???
You've really got me curious.
I can't help but guess, are any of them:
- volume control is more important than pitch
- the theremin is not that hard to play
- pitch Linearity should be adjustable
- ear training is useless if you don't know phrasing
- bent pitch antennas work better
- tubes are better than transistors
- loops should be square
Below is RS Theremin's misconception myth list, it is always evolving.
The list expresses concepts in reverse of what I interpret as the truth.
(Words in brackets are truth.)
--start
Tube amplifiers (tube oscillators do) will give a theremin a better sound.
Clara’s voice is due to the way she “shapes” her volume hand.
To capture Clara’s instrument sound (technique-we need her) is not possible without her.
Hand capacitance explains all that is needed to understand the pitch control.
If a theremin design concentrates on the professionalism of the schematic, detail to the board/chassis layout, components faithful to the original design, a beautiful enclosure, be cautious as this has no relationship to a good sound.
A theremin sounds bad because it is cheap, (design is the issue not cost).
All different future theremin models cannot have similar pitch and volume field response.
Perfect pitch field linearity does not add anything to developing your playing ability.
A beautiful sound does not encourage better playability.
Operating your pitch oscillators at the lower original frequencies works better.
Large air coils have more advantages over small high Q ferrite inductors.
Single diode detectors are less effective than more complex configurations.
The signal removed by diode detection from heterodyning is a 1/2 wave shape. (What is detected is one side of the two symmetrical sidebands plus the mixed signals.
--end
Anytime someone talks theremin or sales without demonstrating a “sound byte” RUN!
This sample below is my “personal” sound which endorses my Myth list. It develops from a pitch oscillator operating at 900 kHz, is drift free, uses small high Q ferrite core inductors with simple single diode detection giving me an ideal sine wave. Pitch field linearity is perfect (not almost linear) using a custom antenna.: My Theremin Sound .mp3 175k Can't play a tune though )-:
OK Theremin World…
I know what you’re thinking: 'Did he fire six shots, or only five?' Well, to tell you the truth, in all this excitement, I’ve kinda lost track myself. But being this is a .44 Magnum, the most powerful handgun in the world, and would blow your head clean off, you’ve got to ask yourself one question: 'Do I feel lucky?'
Well, do ya, punk?
