I too noticed some distortion on my Theremax. I discovered that it was some bleed thru from the volume oscillators to the pitch oscillators.
I was able to eliminate the distortion by tuning the volume coils such that their frequencies stopped producing audible distortion.
Using the jumper cable to force the VCA "open" (as described on page 20 of the Tmax manual) simply tune a pitch (by turning the pitch knob or positioning your right hand near the antenna. While listenning to the pitch, tune one of the volume coils (L3 and L4) and then the other and you may notice a spot where the pitched sound becomes rough or distorted. My solution was to experiment with different pitch coil settings and to see if there was a volume coil setting that would allow a clean signal throughout the pitch range. I don't have a scope or an accurate frequency counter thus I can't provide you the exact frequencies that I used... however, about 30 minutes of effort paid off in getting a clean, undistorted tone throughout the Tmax's range (The Tmax has a (playable) range of 6 1/2 octaves).
While I wasn't getting audible hum when plugging the Tmax into my board I was getting a rough sound. I plugged the Tmax into an EbTech Hum Eliminator and the roughness disappeared.
The Gate LED pulls the pitch down nearly a quarter tone and I have been playing the Tmax with the gate control fully counterclockwise (which kills the gate signal). The LED is very bright -- I am going to substitute a larger resistor value in series with the LED and hopefully will produce a dimmer brightness and not pull current from the rest of the circuit.
I haven't modded the Tmax though the square wave output is a bit bright for my taste and I am considering use of a low-pass filter to tame the sound a bit. I would like to brighten up the basic heterodyne signal and I understand that one can substitute capacitor values to accomplish. (Paia's website has some suggestions for different capacitor values).
I would add that Scott at Paia was extremely helpful -- we did quite a bit of troubleshooting over the phone.
Good luck with your Tmax!
