Hi,
We are trying to build a Paia Theremax and are having some troubles. We are implementing this on a breadboard so we can experiment with it later. So, this is for fun, not to make a completed product.
The problem we are having is that we are getting no audio output. Don't worry, we have more information than that! :-)
First, our test environment. We have tied the volumn pot high to bypass the volumn osc. per the tuning instructions in the manual. We have a 'scope, multimeter, and function generator at our disposal. We have disconnected the antennae. And finally, I cannot spell.
We strongly suspect there is a problem with the osc. or the mixers. To verify the operation of the rest of the theremin, we disconnected the pitch oscs. and hooked the function generator to C23 (the input to the filters and amp). The result is the audio output one would expect from the theremax.
The osc. seem to be working to some extent. When we measure the emitter of the osc. transistor (Q1, Q2, Q3, Q4) we get 500 - 600 KHz (which seems low, but OK), ~150 mV RMS, with a ~1.8 VDC offset. This is all pretty close to the manual's spec.
However, when we measure the output of the osc. coils (tap 4 of L1, L2, L3, L4) we get nothing measureable. It maybe that the output is too low for our 'scope, or it may just be flat. (We noticed when using the func.gen. that the theremin works really nice with inputs of under 35 mV RMS).
Likewise, the collector of the pitch amp. (Q8) shows a ~+5VDC with no AC.
We have quintuple checked the wiring, we are 100% confident that it is correct. Similarly, the fact that all four oscs. and both mixers act like this indicate that it is not a faulty component or bad wiring. Out of frustration, we went ahead and metered all of the involved resisters, caps, and diodes. They all check out.
If you are still reading this, then I owe you a beer.
My questions:
1. Is the output of the oscs. really that low?
2. Can you provide any direction on where we should go with our testing or flat-out tell us what we are doing wrong?
3. Can you provide any information on how the mixers work (D3/D5 and D7/D9) for our own understanding?
Thanks,
Ted Young
My questions:
Thanks,
Ted Young
