"I didn't realize that the wood could have an influence on Q." - André
I haven't done an exhaustive analysis of this, but noticed years ago when performing my hand capacitance experiments that a wooden stick against the antenna influenced the frequency in a way that a plastic stick didn't at all.
"Anyhow, moving the coils is not difficult. The inside height of the box is 60 mm, so I can space the coil equally 1 cm from top, bottom and side."
Sounds good.
"Could there be a problem if the pitch coil is too close to the Prozor DACs? I will be at 1 cm also, instead of 2 cm now."
I would worry more about placing the coils close to significant metal and / or operating circuitry than wood. But it is all relative, and experimentation here gives the final answers.
Since fields drop off as the inverse of the square of the distance, even small separations can help. The moisture content of the wood is likely a factor. Not hollering at you at all, and it's hard to know how much the wood might be influencing things (most likely not a lot) but I try to discourage folks from disassembling the coil / AFE boxes in the kit unless there's an overriding reason to do so, as the boxes guarantee some minimal distancing for the coil, and the AFE is placed off to the side where it services both the hot and cold ends of the coil (something of a compromise position).
I just noticed that both coil wires seem to be coming out of one end of the coil? That is likely more of a problem than any proximity to wood. It would be best to run the low impedance drive wire outside the coil and away from the high impedance hot sense end of the coil. Think of the coil itself as an antenna, with 0% sensitivity the cold end and 100% at the hot end, and with a gradient along the winding length. You can run your finger along the coil and see this effect on the tuner. Running the cold wire so close to the hot end of the coil is almost certainly reducing some of the absolute sensitivity.
"For the LED brightness I will try 6.8k resistor value, which is the maximum specified on the data sheet (page 14)."
Let me know how this works for you. The current value tries to balance dark room viewing vs. bright stage viewing, but the dynamic range isn't the best.
"Since the current is given by the resistor value, what is the adjustment principle by the LED parameter on the Diplay screen? PWM?"
The brightness knob sends codes to the analog drive circuitry in the driver ICs to control the overall brightness. PWM is used for the grayscaling between LEDs.
"I will post better ones when I move the coils... next year!"
OK, I'll wait until then, thanks!
