20mH Solenoid
I 3D printed a clear PETG coil form, diameter 88mm and 140mm long, with 2 separately printed rib stiffeners added to the inside:
The print Z-stepping was set to 0.18mm, which is the OD of 34AWG single coat magnet wire. Even with these as a guide, winding it was something of a bear. The final inductance was somewhat off of that predicted by my coil program at 19.3mH. DCR was 148 ohms. Aspect ratio is 1.5.
On the test jig resonance was 1.66Vpp @ 265kHz, which means a Q of around 155. Not super hot as the kit inductor Q's are around 170, but not super bad either.
Also messed with a bit of ferrite in a smaller 1mH solenoid:
Resonance before and after inserting the ferrite was 1.1723kHz => 765.2kHz, or a 2.35 magnification of inductance. Q before and after was 131 => 114. Again not the best but not crazy bad.
I need stick both of these in the freezer to see what's going on with their tempco's. My new LCR meter has more resolution than my old LC meter, and I guess I trust it more to be stable over the warm-up period.
