Hello,
I've been trying to get the mk II Jaycar theremin to work, most recently I am getting no voltage reading and no continuity between ground and TP2..
There is 9V at TP1, however you should know that I have already taken the liberty of doing the first two of Thierry's mods: adding the two potentiometers for fine pitch and fine volume tuning.
I also have replaced 2 of the RF coils because I messed two of them up with a metal screwdriver. I bought a set of 4 coils for AM radio and the label indicated that the 1st and 2nd IFT (the YELLOW and WHITE coils) were interchangeable, so I used both of those.
I have also already gone ahead and started making a hexagonal box and have 10mm aluminium rods for the antenae.
Is there anything I can do to test what is going wrong? I only have a multimeter to use.
Thanks
