A quick question - I recently built a pedal based on a schematic for the interfax harmonic percolator, a type of fuzz pedal with mostly second order harmonics. While it works perfectly, and sounds like it should, with guitar, when hooked up to the theremin (etherwave standard) weird behavior happens. It does at modest settings I think improves the etherwaves tone, making it a bit more string-like, i think it, or the general idea, might have potential, but -- the theremin becomes un-tunable. and moving near the pedal changes the theremins pitch drastically, its like the etherwave has a second pitch antenna. I connected the grounds through the metal case, if that matters.
What may be causing this? Is there a solution? When building pedals for theremin use what else does one have to consider in general (except changing the values of high/low pass filters)
If it matters the schematic I based it was off of http://www.madbeanpedals.com/projects/PepperSpray/docs/PepperSpray.pdf I used slightly different values depending what was on hand, and russian ge transistors/diodes cause they were cheaper, [it sounds like what the pedal is supposed to sound like on guitar] but the circuit was basically the same.
