Hi,
I just finished building my PAiA theremax kit. When I first tried it I got no sound, so I turned it off and did a visual check. I found a loose capacitor, so I soldered it on, but still no sound. So I followed the troubleshooting steps and found that the voltage was reading 8.5V at a point where it should read 8.2V (R1 to be specific). I figured I'd better get the voltage down to 8.2, I didn't want to fry anything. So I replaced the resistor that was responsible for this (R1). The original was 100 Ohms, I put in a 200 Ohm resistor and the voltage dropped to 8.15V. I figured that was pretty good.
Turned it on, tried again, still no sound. To be clear, as I adjust oscillator coil L3 the gate light does turn on and off as the manual says it should. Also, i can get the gate light to respond to me moving my hand closer or farther away from the volume antenna. I sometimes can hear a faint crackling noise as well. There was never any smoke, or burning smell. I have gone back through the manual and checked every part and connection and I can't find anything wrong with what I did.
What should I do? I'm completely stumped.
Please help
Thanks
