Insulating the volume loop & antenna
Posted: 2/20/2014 9:01:49 PM
Darcmorcel
Hi everybody,
I just began practicing the theremin and I saw that one could put insulating sleeves on both volume loop & antenna to avoid static electricity.
Could someone tell me were to find what I need to do it myself ?
Thanks !
Posted: 2/24/2014 1:22:36 PM
Sillyconica
FredMs Posted:
 2/8/2014 8:17:46 AM
http://www.thereminworld.com/Forums/T/29285/relationship-between-series-lc-and-parallel-lc?Page=1
 really  sleeving may look nice and stop ew chirping but its not going to save thereman from static will just jnmp through sleeving as if it wasnt even there
Posted: 2/24/2014 2:01:29 PM
Heat-shrink tubing should do the trick. It is easy to put on, is available in a range of colours and gives a very professional finish. Buy some with a wider unshrunk diameter and a narrower shrunk diameter than the antennas.
A couple of caveats - as with any modification, test it before you make it permanent - removing it after shrinking would require a sharp knife and the possibility of scratching the antennas. If you have an etherwave, watch out for your nuts - they won't fit over the tubing. You can remove and replace the compression rings on the volume loop by twisting them with a pair of pliers.
Posted: 2/24/2014 2:52:33 PM
RS Theremin
Hello Darc,
From France hum….  Back in my hippie days I had a dear friend from St Avold, she and I traveled around California looking for adventure. Anyway all journeys end.
Something that seems to be avoided in theremin tricks, I like to feed a rubber insulated wire inside the EWS volume loop connected where the thick wire connects. This way the loop looks purty and there is no direct contact and it gets rid of the chirp if you have one. Unsolder the thick wire from the loop, easy enough to put back as normal.
The Pitch antenna I have more reverence for and leave as stock.
I have been at the theremin stuff for over ten years now and my final theremin design does not have any antennas, what? and will give the Hoffman theremin a run for its money. How this is done is on my public webpages but I make people search for it as nothing about the theremin comes easy.
It is a profound approach! No metal plates and a perfectly linear pitch field.
Watch that mean guy come along and slap me up side the head!#$%
Edit: I do have a EWS Tips & Tricks webpage with nothing to sell.
Posted: 2/24/2014 3:20:00 PM
bisem
I used this braided wire sleeve on my etherwave that I purchased on ebay:
http://www.ebay.com/itm/271343599252?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I believe Thomas Grillo uses a similar product.  You could even go a size smaller since it expands a lot.  I cut the sleeve and melted the ends with a lighter flame to keep it from fraying.  Also a small drop of PVCE or similar glue wiped around the antenna near each nut keeps it from contracting and holds it in place. I only use it on my volume antenna to avoid the popping sound when accidentally touched while playing.
If you are using it to prevent static discharge it will only offer a very limited protection from what I have read on here. I do have a fried circuit board on my old Big Brier Etherwave that I believe may be form a static discharge.  Since reading about the problem on here I have gotten into the habit of touching the front plate of the instrument before playing to discharge any energy I may have picked up before approaching the theremin.
Posted: 2/24/2014 7:18:23 PM
Darcmorcel
Hi everybody, thanks for the tips and links !
I forgot to mention but yes I recently purchased a Moog Etherwave Plus.
As I'm not ready yet for soldering, I'll stick with the sleeves (+ touching the frontplate) solution but thank you @RS Theremin :-)
@ GordonC & bisem:
Could you please tell me what size I have to pick up for heat-shrink tubing or braided wire sleeve ?
I cannot reach the ebay page mentionned by bisem, thank you country restrictions :-(
Posted: 2/24/2014 8:29:44 PM
Darcmorcel, the etherwave antennas are very slightly less than 10mm in diameter. (3/8" = 9.525mm) If you get 10mm internal diameter tubing it will slip on with the aid of a lubricant. If you get a larger diameter heat shrink tubing check that it shrinks to less than 10mm.
Sillyconica, I think you misunderstood me. I was referring to the nuts on the theremin - the ones you keep tight to stop the loop from drooping and the rod from sticking up at a funny angle.
Posted: 2/25/2014 6:27:47 PM
Darcmorcel
Thanks Gordon !
just found some 12mm tubing that shrinks to 7mm, it should do the job very well...
Posted: 2/25/2014 7:50:50 PM
Cool. Do try playing your theremin with it just slipped over the antennas before you heat-shrink it. Just in case.
Posted: 7/28/2015 6:24:35 PM
xtheremin8
hey theremincat,
got a towel? don't panic about all tose possabilties of esd etc. i've been in colmar recently to meet thierry and many other dedicated people. so far, my theremin does brief tweeteledees when i touch the volume antenna. thierry told me, that some do because of the circuitery inside and some don't.  i really avoid touching it, no rest for the volume hand. but i know how my body can build up static electricity, it can go up to thousands of volts, so i never scuffle around in wool socks on some fitted carpet etc. i like woodfloors. good for sound and statics.
maybe some good dips  into a clear lacquer does the trick too, specially if the nuts and stuff is already mounted on the antenna. hmm should try that one myself!
yr scientific question, if the faceplate is grounded, mostly by the out-jack, that's where the static goes: to ground. if you are really loaded, you might feel a little zap. kissing on escallators? zip? or balloons rubbed on a pullover....blip.
