This is related to recent posts on Dewsters "digital theremin" thread related to EM radiation from theremins:
The question of EM radiated from a theremin .. What emits it, is it from the antennas, the inductors, or somewhere else - how bad is it...
Well - its a thing that has bothered me a bit with regard to monitoring or 'previewing' using an AM radio.. As has been discussed at TW a few times...
You see, I have never understood how this could work if the signal being detected was being transmitted from the antenna...
Ok, the fact that it works to any degree shows that EM is being transmitted... But what produces the audio? If this was the result of heterodyning the VFO frequency on the antenna with the radio's local oscillator, then the audio pitch from the radio would be different from the audio produced from the theremin, because the chances of both the radios LO and the theremins reference oscillator being exactly the same are, well, quite small ;-)
So ok - On the EW, the mixer is really crude - so both reference and VFO signals could be mixing and a AM signal (beat frequency) could be appearing on the antenna I suppose - But I doubt that this is whats happening, and it certainly wont be happening on any EW with a buffer, or on any other theremin where the oscillators are buffered or otherwise have no route by which AM could be appearing on the antenna.
But if the radio is just picking up the VFO from the antenna, and not mixing this somehow with the reference oscillator, and not beating this with its own local oscillator, well - we shouldnt hear audio from the radio ! should we ??
I suspect / hypothesise that the reason one can hear theremin audio on an AM radio is because this EM is being radiated by inductive components in the VFO and REFerence oscillator circuits, is mixing in the "aether" or in the radio circuitry, and is probably not coming from the antenna at all...
I have done almost no RF "probing" of this type at all - have never put a radio to my prototypes, and have always been quietly sceptical of this practice, mainly because I didnt trust that any 'results' would be meaningful, because there were "unknowns" involved with any radio I used for such "testing".
The biggest unknown probably being any possible interactions caused by the radios local oscillator (or oscillators?) (heterodyning or superhet?) As I dont feel competent with radios and am not particularly interested in them I simply avoided using them - particularly as I have test equipment I understand and trust which does everything I need..
But as the whole EM matter is topic of the week, I thought it as good a time as any to float this... Usually I avoid mentioning anything EM related at TW ;-)
So my questions are these:
Does radio previewing work?
Y -> is the audio from such previewing the same frequency as the audio from the theremin ?
N -> Ok, then nothing is "proved" - EM from the antenna could be mixing with radios LO.
Y -> how does the reference oscillator (which is not connected to an "antenna") get recieved, or mixed, or whatever, to enable an AM radio to reproduce the difference frequency ?
I should also add that if I remember correctly, last discussion on radio previewing. the tuned frequency of the radio at which theremin audio was detectable covered about 4 harmonics (as in, say the VFO was centred at 250kHz, audio was detectable when the radio was tuned to 250, 500, 750 and 1000kHz) ... Now that struck me as quite odd - because antenna waveforms I have seen tend to be quite sineusoidal - having strong EM up at the 4th harmonic just didnt seem 'right'..
However - signals, particularly the drive / excitation pulses, in oscillators (and through their inductors) can be quite rich harmonically - Also, if care is not taken in the decoupling of circuits, one could easily get strong radiations from tracks and whatever..
