starting to learn
Posted: 3/23/2014 4:47:09 PM
v7peer
Hello,
a few months ago I build the Etherwave Standard kit. Then I started to work with the method of Victor Estrada. After a few weeks I began to feel a little bit secure.
Then I saw a video of Carolina Eyck. The 8 positions looked difficult but I decided to try it. I bought the book and tried her method. At first it was very hard. I could not find a good starting position. Now a few weeks later I noticed that when I have found the starting position I can play the scale.  I also discovered the nonlinearity of the Etherwave. I find that for me playing the scale upwards is easier the playing downwards.
The method of Carolina helped me discovering the possibilities of the Etherwave. But I am still searching for the steady handpositions that will work for me. I notice that I am using slightly different positions and I find it difficult to work with the combination of the fingerpositions and the bending of the wrist.
Today I have build the ESP01-module in the Etherwave. That is a great improvement. The Bassrange is expanded, the sound has changed (I like the new sound) and I think that its more lineair then it was (I am not certain). I can recommend the ESP01-module.It really is great.
Meanwhile I look at the dvd of Peter Pringle and I think that I am going to switch to his method. I like to improvise and it seems to me that the four position method will be more useful for my way of playing.
And yes, the theremin is very difficult the learn but it is very attractive at the same time.
Posted: 3/23/2014 8:01:17 PM
Amethyste
You will see and find out, that over time, you will mix methods from different thereminists for your own physiology. I use Carolina's mainly when I go upward in the notes/scales, but I do some knuckle or wrist shifts
when I go downward. Peter's method does not work for my hands.
Posted: 3/24/2014 4:32:28 PM
v7peer
Yes,
I think that I will use a mix of several methods. But for now I am just trying different techniques to discover what is the best method for me. Also I need to learn to experience how the thermin behaves. In time this will work.
What I like in the method of Peter Pringle is his base handposition. It looks very solyd. I believe that the biggest challenge is to get a steady hand. In the video's I see that Peter gives much attention to the starting position before he starts to play. He is stabelizing his hand and body. I am going to try this too.
