"The sound was not the clean and pure theremin sound that I was looking for but somewhat distorted and fuzzy. Since I understand nothing about electronics I have no clue in finding out the actual problem." - Hande
The K450FX should be able to give a good clear undistorted audio out from your theremin. I have used quite a few Behringer products, and always found them to be exceptionally good - as good as most products at double the price..
"somewhat distorted and fuzzy." could be due to over-driving the input - You have a level control for each input, and a master level control - Plug your theremin into an input that is Line only (not one of the shared line/mike inputs) - turn the input level down to minimum, and slowly increase it, using the master level to adjust the loudness.. If the sound is clear until the input level is cranked up beyond some point, you have found the problem - keep the input level control below this level. I believe there is a way on most of these amps, to route a line input direct to the output bypassing effects.
The K450FX also has quite an extensive effects unit, with various routing possibilities - It may be that you have routed the signal through this and this is giving the 'distortion'.. Also, there is a graphic EQ with (I think) a feedback processor or at least an indicator.
This isn't just a simple amplifier (although, in terms of modern audio equipment, it is really simple ;-) - you cannot expect to operate it correctly without first reading the manual thoroughly, particularly if you aren't used to audio equipment, "understand nothing about electronics" and "have no clue in finding out the actual problem".
It MAY be that the unit is faulty - but I think it more likely that you are doing something wrong. I played a theremin (not an EW) through a Behringer amp last weekend, and it sounded fine - The band I was mixing had Behringer amps for the whole backline, and I was using a Behringer mixer for the PA driving EV amps and speakers.. No, I dont work for or get commission from Behringer, but have never seen one of there products misbehave or cause any problems.. But I haven't ever played with the K450FX- Have played briefly with some of their bigger siblings though.
