Here is a new video featuring Samuel Hoffman’s RCA, along with its recently restored and installed RCA 106 Radiola Loudspeaker.
If you look carefully at the inside of the RCA cabinet, on the lower tier, just to the left of the power supply, you can see where the RCA 106 Radiola is plugged into the AC jack designed into all RCAs specifically to power the speaker. I deliberately left the new, white, rubber plug and cord as is, to distinguished them clearly from all the other cloth and fiber-wrapped wiring in the instrument which is original.
Unfortunately, the 106 apart from producing “the” sound that the instrument was intended to produce, also produces a low frequency buzz. According to Andrew Baron (who has had quite a bit of experience with these speakers) this is normal for the Radiola. In a live performance, with an accompaniment and an audience several meters from the player, this buzz is not noticeable but with a microphone just a few inches from the speaker, as it is in a modern audio or video recording situation like this video, it is quite annoying.
I mike this theremin with an Audio-Technica studio microphone, which goes directly into a MILLENNIA STT-1 (which also phantom powers the mike). This device, which uses vacuum tube technology, allows me to remove the buzz before the signal is output to the audio recorder, and it does this very gently without altering the pure sound of the instrument. One of the many wonderful things about the STT-1 is that it can surgically remove specific frequencies with no identifiable collateral acoustic damage or sonic “holes” or gaps in the frequency range.
What is left is a sound that is, IMNSFHO, quite pure and spectacular, particularly in the upper-mid and upper octaves. And with the Radiola, we are presumably hearing the sound that Lev Termen intended for his RCA theremin. Hope y'all enjoy!
https://youtu.be/OPQLLUyIsUo
