Help needed with Theremini MIDI problem.
Gordon,
I connect my Behringer foot controller to the Theremini and have no problem sending any of the MIDI CCs (but I use a USB hub that can be a host).
What kind of MIDI hub? I think that's your problem. Are you also going through a computer? Normally you would need to add that to the MIDI setup unless you have a device like the iConnectMIDI4+ that has the capability of being a USB master/host basically letting you connect a MIDI controller directly to the Theremini without a computer in the mix. So check if that is just a dumb USB hub or if it has the capability to be a USB host.
Do you have a laptop or something you can add to the hub to be the USB host if that's the issue here? An iPad with a slider app connected to the Thermini may also do what you want though of course you need a free hand or someone else to control - but a slider app will let you control multiple parameters easily too to do some nice things.
Rich
Hi Rich. I have narrowed it down to a problem with the eowave pedal - the configuration did not hold and it had reverted to CC1. It seems other people have had the same problem and I did not find a solution. Synthguy is helping over on the moog forum, and hopefully we will find a workaround using the MidiBridge app to remap the output from the eowave.
It is a dumb hub, but my iPad mini works fine as a usb controller.
I probably could do it from a slider app, but as you point out a free hand is required. I've had plenty of practice at playing while operating a treadle with my foot and it's my preferred solution. :-)
