Hi Guys.
My name is Carlos. I'm hoping you can help me troubleshooting a Theremax clone I built from scratch
I used an older revision of the pcb (version 9505B) that I modified for current specs (version C)
The thing is that I don't have the voltages that are supposed to be present in some parts of the circuit.
I followed the troubleshooting info at PAIA with no results.
I only "modded" the control panel, using two separated pcb for the jacks and the pots respectively.
I triple checked the board and the daughterboards and they are ok.
Also checked all the resistor values before installing, and after visually (in some cases I pulled up some resistors that I doubt and remeasured them)
Maybe there is a crack or a bad solder joint I'm not seeing
Thanks in advance for helping.
Here are the voltages I'm geting:
LM339n
1:0,03v 14:0,15v
2:0,03v/7,55v 13:1,68v/2,10v
3:8,06v 12:0v
4:4,01v 11:4,00v
5:3,96v 10:0,15v
6:4,01v 9:0v
7:3,97v 8:0,49v
(Pin 2 goes high when I short circuit it with pin 3 and stays like that until I short it with pin 1)
Q1
C:7,08
B:2,11
E:1,55
________
Q2
C:7,02
B:2,20
E:1,80
________
Q3
C:7,03
B:2,20
E:1,72
________
Q4
C:7,05
B:2,20
E:1,63
________
Q5
C:8,05
B:0,02
E:0
________
Q6
C:8,05
B:0,02
E:0,06
________
Q7
C:8,05
B:0,03
E:0,01
________
Q8
C:4,07
B:0,59
E:0,01
________
Q9
C:4,90
B:0,59
E:0,01
Q10
C:7,60
B:3,82
E:3,50
________
Q11
C:7,58
B:3,79
E:4,16
________
Q12
C:4,05
B:0,31
E:0,01
lm748
1 1,34
2 5,83
3 5,80
4 0
5 1,26
6 4,03
7 8,06
8 3,44
