Before my last etherwave build, i tried some different coils.
I have build just the oscillators as a prototype with the values 1k5/330R for the resistors.
Then i tested with coilcraft slot 7(104 and 683), "Filterspule 60uH" from Box73 aka Funkamateur and others i had in stock.
Allways without a second series inductor, i changed the tank capacitor to get the frequency i wanted.
On the workbench all worked fine, without problems.
In my final build i have choosen the coilcraft 7M3 ones.
I read a post here, i think it was Thierry, that using those 7mm inductors can cause problems due to "wiring capacity"(sorry, i dont find the correct term, my english is not the best).
Actually, all works fine, perhaps also depending on the PCB layout in the case of different routed PCB´s
