Hi, welcome Daniel,
most useful effects for theremin would be delays and reverbs, of which the multi-effect pedal probably has several types (tape echo, analog delay, spring/room/plate/hall reverb), and modulated effects like chorus, flanger, phaser, rotary speaker simulation can have their place, 2 or 3 wah effects set to different bands can simulate vocal like formants (vowel sounds), while a filtron/envelope filter can make the timbre variable with volume.
Fuzz/distortion effects can also be used to change the timbre/wavform, and can also compress the dynamics, so you could get a snappier attack, but at the cost of a reduced dynamic range. Octaver and pitch shifting can be used to extend the range down or up or to add fulness/harmonics or a tone at some interval with the theremin's tone.
A looper function is great, to record something to practice over, or to create something layered/polyphonic.
Filters (wah or equalizer) can be useful, also to use in front of and after a fuzz/distortion. When chaining several effects, the general guideline is filters (EQ/Wah) and fuzz/distortion first, then pitch shifting and modulated effects, and reverb and/or delay last in the chain.
It's often a good idea to use more dramatic/extreme effects sparingly, and otherwise use effects in a subtle way, on the border of being noticeable. But much depends on context and style and what kind of sounds you are after. Spending more time tweaking effects than actually practicing and playing theremin wouild be counterproductive.
