I remove my posts above because I a firm believer in not clogging up the google database with nonsense due to ego driven “I wished it worked”. In our conversation my goal is to figure out if you have the drive in your gut to really do something original. Over twenty years I have helped a couple of hundred dreamers.
We are at the 2020 Theremin celebration and it seems I am missing something, I watch what Pro Thereminist must use, I am saddened.
This is the
Classic Sound of my original design, had this 10 years ago and modern engineers prefer their muffled whistle.
Charm, I will send to you (Europe) anything not available at no cost even all the Mouser Parts, and the Pitch Electrode. How this approach came about is not important but it works in a “startling” fashion, like Lev Sergeyevich must have been startled the first time he heard heterodyning.
Static discharge is a non issue in my design, a fatal flaw in most modern Theremins, I guess that is for the purpose of more sales.
Probably not obvious my Pitch detector uses induction coupling of the two RF signals. This keeps them isolated from one another; over coupling is what causes the low end distortion of a EWS.
If I was to try something different it would be to use a different Pitch L1 & L2 coil, again these create the induction coupling to L3. The ThierryMin gave me this idea with a var cap. That guy is so dam smart, most of the time.
My Volume Control is much more sensitive than the standard design, this allows for further possibilities. You see the loop, for my design the wire inserts less than 4" or 10cm The capacitive coupling insertion depth controls the sensitivity.
Edit: I build in a modular fashion so sections can be swapped out with improvements. Having the Volume separated from Pitch allows more comfort in how they are positioned. Have you ever met a Wounded Warrior Musician that lost hope?. Theremin design is a never ending project and more.
Edit2: Both 3.3mh choke/coils are mounted on the PCB The Pitch Electrodeum is parallel tuned, unlike the series coils of the EWS
Edit3: To build on a single board with smd parts would be fine if you think you have the layout of a finished product, why not? Then again your first build should be done my way so you have a feel of what is going on.
The Theremin is Not Magic, don't kid yourself, her goal is to kick your ass.
