Mic stand connection
Posted: 4/29/2020 10:45:29 AM
MuteNewt
Not sure if this is the right channel, but have a question around mic stand connections. I recently received a used big briar Etherwave theremin that seems to have lost the piece that connects it to a mic stand at some point in its life. It’s been working fine on a table top for now, but I’d like a bit more flexibility. Any advice on what I should get to replace the connector. The original drill holes where it was screwed in are there, so something with the same spacing would be best.
Posted: 4/29/2020 12:07:03 PM
I use this one, not sure if the mounting holes will match:
https://www.amazon.com/gp/product/B0002GY10M
"Atlas AD11BE 5/8-Inch 27 Thread Surface Mount Female Microphone Flange, Ebony Finish"
Posted: 4/29/2020 4:17:54 PM
DanielMacKay
Wow, I'm sure glad they included that photo. Without that I would have had no idea what I was getting.
Posted: 4/29/2020 4:40:29 PM
Hello MuteNewt,
This might work
Posted: 4/29/2020 9:11:46 PM
"Wow, I'm sure glad they included that photo. Without that I would have had no idea what I was getting."  - DanielMackay
Ha ha!  I can see the photo in my old orders, not sure why they're not linking to it.  It looks like this:
Posted: 4/29/2020 9:21:56 PM
DanielMacKay
dewster: ahahah thanks for the image.
MuteNewt: you may want to turn this 1/6 turn off the previous orientation and not use the existing holes; there's a chance that they were stripped or loose. If you turn 1/6, mark and pre-drill new holes you'll have fresh strong wood to screw into.
Posted: 5/1/2020 6:24:53 AM
MuteNewt
Thanks all, one of these should work! Good call on rotating it, Daniel, that solves the potential spacing issue as well.
