Hi all,
I'm extremely new to this (read: clueless), and recently put together a Gaudi Arduino shield. I was able to upload the v3 code through the desktop IDE, and the red LED is on, but I get absolutely nothing when I try to calibrate. The yellow LED has never turned on, and when I hold the function button I get no sound, or the occasional brief and very faint sound from my speaker that sounds like static or popping. When I try to use the serial monitor, it remains blank. I'm not sure what the fix is, and I'm hoping someone has some insight on what I may have done wrong, or what I should check.
Thanks in advance!
ETA: I have a grounding wire attached to my PC, the Uno is powered via USB currently, and I have attached a small sound bar via the audio jack
